driver rear disc got hot as heck today...? 2 questions...
Old 02-20-2009 | 06:19 PM
eodjeep2000's Avatar
I got home and noticed that I had a VERY hot disc. I pulled it apart and can't tell why the caliper didn't release. One of the pads (outboard) was a little rough. Disc was fine (although discolored from heat). E-Brake was fine.
1. Why wouldn't it release? Is it common? It's never happened on my truck before.
2. How the heck do you pop the pads out? I have the caliper off right now and can't get the pads out to change them. It seems like the clips should pop off or something but I don't have a spare so I don't want to go a-prying...
Damon
Old 02-20-2009 | 06:24 PM
mopar-or-no-car's Avatar
The pads come out bypulling them sideway like the outer one pull away from the truck the inner one pull towards the frame, and pull on the top of them so they come out at a bit of an angle that way the claer the clip.
My back passenger caliper stuck on last year and i noticed becouse i saw smoke pouring off it in the mirror, Im not sure what caused it but i just replaced the caliper and I just changed my front passenger pads and rotor becouse it had stuck on and worn the pads right out and ruined my rotor, so its not that uncommon.
Hope this helps.
Old 02-20-2009 | 07:33 PM
dozer12216's Avatar
Rear caliper is hanging, replace both.
Old 02-20-2009 | 07:36 PM
Duh....I was thinking about the problems with the rotor when I took it apart so the pad carrier and the caliper were removed as a unit making disassembly "difficult". After I took them apart pad removal became obvious.
Thanks for the help!
Damon
Old 02-21-2009 | 09:19 AM
I'm ordering one now....but why both?
Thanks,
Damon
Old 02-21-2009 | 06:13 PM
dozer12216's Avatar
You want to do the same job, opposite side, in another two months! Both have been subjected to same environment. Caliper pistons may have different residual friction as result. Believe that is accepted consensus.
pullin hard
03-05-2009 08:06 PM
n2moto
16
01-22-2009 10:25 PM
ShawnQ
01-12-2006 08:09 PM
billyrae
05-24-2005 03:42 PM
kwhite4
05-09-2005 03:22 PM
Quick Reply: driver rear disc got hot as heck today...? 2 questions...
