Drilled into Manifold Splitter
Hi there, I went to put in my pyrometer probe and I drilled right in the center of the manifold elbow and I drilled just to the left of the splitter with the drill hole half on the splitter and half not, how should I plug this while keeping the manifold on, with a weld, or a bolt? what should I do?
Location: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
1 Post
I'd just tap the hole and thread in a plug. I would NOT use a bolt. It may be too long and hang down into the pathway.....
ya that is what I was thinking, just drill it deep enough to put the probe in, then tap it and just put the probe in, I don't think it will affect the EGT reading much at all, the only thing is weakening of the manifold.... think it would be ok?
1 Post
No. I would not put the prob into a hole where it will be up against a wall or divider. You'll get erroneous readings. Put a plug into the hole you made by mistake and redrill a new hole in the proper location and pu the prob there..........
Got it, gonna tap out the old hole and do that, thanks for the help guys, hey the devit where the bridge was that won't be filled by the plug will that affect airflow enough to notice it?
SundayMoney
04-24-2009 09:14 PM
iweb
25
07-01-2007 08:52 AM
akeithbrown
12-28-2004 02:26 AM
Dodgezilla
21
02-03-2004 04:26 PM
