drained water separator now wont start!!
drained that separator for the first time in my garage and now it cranks but wont start....its a 95...i found that lil primer button am i supposed to pump that?? or hold that? or something else?
I remember reading something about a bleed screw as well.
Check this thread before you try anything.
https://www.dieseltruckresource.com/...threadid=60027
phox
phox
First open the bleed screw on top of the filter housing, it's the 10mm bolt towards the front on the outlet banjo bolt. A couple of turns is enough. Push the primer button with a short piece of wood doweling to save your thumb.
Next time only open the water valve for a few seconds and you won't have to prime it.
agh ...save my thumb u say?? my thumb feels as bad as id did when i was 12 and was playin super mario 3 all night with my friends!! but the thing started after i primed that button about 30 times...now its fine....when i was draining it i was holding it for about 15 sec ...i learned my lesson
once again thanx boys!
Andrew
Andrew
GaveUpOnTV
16
01-07-2008 05:30 PM
mattzram
10-09-2006 11:38 AM
fitzydog
04-21-2005 09:04 PM
