diesel will only idle
Old 04-07-2004 | 03:18 PM
gblsmoon's Avatar
My 1999 Cummins will only idle i replaced the apps and it still only idles. When i try to throttle up it just misses hope someone can help
Old 04-07-2004 | 03:25 PM
phox_mulder's Avatar
Did you replace the APPS yourself, or Dealer?
Might try the APPS reset procedure again, if not for the first time.
https://www.dieseltruckresource.com/...n&onlynewfaq=1
Hope it helps some.
phox
Old 04-07-2004 | 03:40 PM
BigBlue's Avatar
Sounds like the VP is dead. Have you checked the codes?
Old 04-07-2004 | 04:33 PM
gblsmoon's Avatar
i did it my self i am going to pick up my brothers snapon scanner and see what happens thnx for the quick response gary
Old 04-07-2004 | 05:49 PM
cmckinney's Avatar
Sounds like it just needs to be reset. Disconnect the batteries for 10 min and then put them back. Jump in and turn your truck to ACC on position then slow depress the fuel pedal.
Hope you figure it out!
-CM
Old 04-08-2004 | 12:03 AM
J BODY's Avatar
Cost of an APPS would have bought alot of diag time.
Old 04-08-2004 | 12:19 AM
Haulin_in_Dixie's Avatar
You are describing exactly how my VP44 went out. I idled about ten miles to deliver my load in the middle of the night. If so the codes will show it.
gonehuntin
03-13-2006 12:28 PM
Road Work Ahead
02-21-2006 09:54 AM
Mike from Canada
10-19-2004 08:26 PM
Dufrain
06-06-2004 04:24 PM
Paradise Racing
12-12-2003 03:22 PM
Quick Reply: diesel will only idle
