Diesel in a gas fuel system
1 Post
it will melt it if you run a full tank thru it less then a quarter you should be fine. i know it will melt had a buddy who picked up diesel at a store cuz they put it in the wrong storage tank. burned up the car motor
It probably will not start, and if it will, it will smoke blue like crazy, then run very bad.
I'd drain the tank. You don't have to be completely clean, just take the majority out of it, then change the plugs a couple of times since they will foul.
It will be like running 2 stroke oil mix.
Not as bad as the opposite, gas into a diesel engine, that's when you'll get a Kaboom.....
THURENfab.
08-08-2007 07:02 AM
ado2b1
07-06-2007 09:35 PM
Scovo1
30
05-11-2007 01:08 PM
