died and won't crank
Old 01-25-2007 | 03:05 PM
Nape's Avatar
My truck died today and will not start back. It is showing the 01689 code for no communication between ecm and injector pump. What now? Nape
Old 01-25-2007 | 04:55 PM
bentwings's Avatar
Looks like an injector pump. 1st Be sure you have good fuel pressure from the LP. Check the codes again for the crankshaft position sensor. 336 I think. I'm not convinced these go bad as often as they show up on the codes. I think it a result of the no communication but for 35-65 bucks it's not worth it not to replace it. It's Up befhind the starter.
Crack 1,3, and 4 injector lines and see if you are getting fuel. Probably not a drop. That's the way mine was.
A lot of these are just dieing while driving down the road. Mine did, no real warning what so ever.
It's about a 4 hour job the first time. There are a couple good posts with all the tools and instructions including mine.
Pm if you need some more help.
Old 01-25-2007 | 05:40 PM
Ram1999's Avatar
Good advice from bentwings above.
My VP died all at once, no warning but at least close to home.
If you don't have a fuel pressure gauge...get one after you change your LP and VP to keep an eye on your fuel pressure.
If Dodge had put at least a low fuel pressure idiot light in the dash alot of us could have saved lots of $$.
Old 01-25-2007 | 09:55 PM
Nape's Avatar
Tell me it aint so
I have a FASS, it puts out about 9 Pounds at tihe top of the filter before the vp44. I had to put in the low pressure spring to help with the cranking when I installed it. I get good fuel out of the injectors just won't fire up. It cranked a few times but would not stay running. Won't even fire now. Thanks, Nape
Old 01-26-2007 | 12:56 AM
chiefallred's Avatar
checkvalve banjo bolt on return line from vp to fuel tank could be bad. i would invest in that before making any big purchases
WHITEY
12-03-2013 06:16 PM
92smokin blacky
02-28-2011 02:36 PM
ado2b1
12-16-2008 03:19 PM
bighornram
12-06-2008 08:13 PM
Machinos
03-16-2008 01:34 AM
Quick Reply: died and won't crank
