Did I Blow my Head Gasket Again or Worse?
I had my truck down at truck fest on Sunday in Denver and it wasn't running how I thought it would on the track but seemed to drive perfectly fine on the way home. I had to do a 900 mile trip yesterday, 450 of that with an 8k trailer and I noticed when I put the trailer on it was getting VERY hard to build any boost whatsoever (could only do it around 2200rpm) so I drove 60-65mph all the way from Rock Springs WY to Fort Collins CO with very high EGT's. When I popped the hood this morning and started to look around with the motor on I noticed that if I hit the throttle lever that black smoke poured out the passenger side of the #4 cylinder area. I just did an O-Ring, Marine Head Gasket, 60lb Valve Springs, and studs less than 2 months ago with all three re-torques done properly. There was a very small loss in coolant, Maybe .5 ltr and oil seems fine. What did I do????
Also, make sure you did not crack the exhaust manifold.
I would bet that it is external whatever the problem is.
Then find out what is causing your low boost ( torn IC boot, loose clamp, etc. )
K, well you two are possibly right. I am pretty sure the exhaust housing on my top turbo cracked or is leaking somehow. While I have to drive to tulsa in the other vehicle my buddy is going to try and fix this
SeanB23
05-04-2009 08:58 AM
wildchild97
09-25-2007 02:44 PM
Moking 24V
12-15-2004 06:28 PM
Pa outlaw
12-12-2002 12:00 AM
