Dealer ripping me off
I had my trucked towed to the local Dodge Dealer last Febuary to get it fixed. I knew the headgasket was blown but the truck would still run. They yold me it would cost $4k to fix it. I said fix it I need my truck. After 5 months they finally said it was ready. Got the truck back and 200 miles later it started leaking antifreeze from the headgasket around #5 cyl. Took it back they said the head was warped, sent it to get machined and 1 month later said truck was ready. Put 300 miles on it this time and the same thing happened this time at the #2 cyl. Took the truck back Friday and today they tell me the block is warped and I need a new one. To me if the block was bad it would leak from the get go and not 2-300 miles later. CAN ANYONE GIVE ME SOME TECH ADVICE? The truck only has 174k on the ticker...and no coolant in the oil just to the outside...
It probably wouldnt leak from the get go. That being said even if the block is warped it can be decked and run a thicker head gasket. They should have checked the head and deck of the block the first time before they put it back together. When changing a blown head gasket it is common practice to check for a warped head and block if the mehcanic is a mechanic and not just a parts changer.
{Admin edit} stay away from this place..
Admin Note:
We don't name names here.
It keeps our keesters out of legal trouble.
Gross incompetence - I would be livid. At least threaten them with a lawyer before you actually go out and hire one & go as high up the food chain in that dealership as you can - talk to somebody who will actually understand how expensive litigation might be for them. I never have work (out of warranty) done at dealerships anymore - I only go there to buy parts I can't get anywhere else.
And 6 months to do a head gasket job?!?!?
That should be a one day job, add a few if the head needs to be sent out for rework. That dealer is taking you for a ride on your hard earned cash.
Stories like this **** me off!
I hope you get things straightened out and to your satisfaction.
Mike
Situations like this are ridiculous. I would find one of the principles of the dealership, and let them know the specific details of your dis-service including time line and exact work performed and name of tech.
If he can not get you on the road without more grief, and in a timely fashion, I'd promise him you'll be contacting the local TV problem solving crew.
All their advertising budget is wasted with those folks doing a story, and Top Dog knows it!
Have all your facts in order and take copies with you. Before hand look on the net to get the history of the company, principle owners names, what stores they own, everything you can. When you've done your due diligence and present it clearly and concisely you will have much more power.
In a warped situation you get part of the gasket that isnt getting as much clamping force on it. It will usually take some time for the pressure to work between the gasket and the block or head. A block usally wont warp as bad as a head will. If you have a leak from the get go than you would have to have an extremely warped head or block. If your block was warped to that extent it may be beyond being able to have it decked. Whatever the case may be you've had dummies working on yor truck.
I would be asking why it took 5 months for the repair. I'm a shade-tree mechanic and did mine in a weekend (new head) in the driveway. Something there doesn't seem quite right.
Your signature shows a #100 plate but doesn't list any gauges. I'm hoping that you have some as even a #100 plate can get things very hot and high boost on a stock charger is a recipe for failed head gaskets. I'm not saying you are to blame, but there may be more to the cause than just the dealership. You may also want to look at where your timing is if it has ever been changed or may have slipped. This can also lead to recurrent HG blowouts. Not pointing fingers just offering other thoughts before you get a new block and head and have the same thing happen again. It's never fun to be without the truck for any reason.
For that kind of time and money you could have gone with a re-man engine. Like steveh1155 said, i'd be livid and looking for an attorney. unfortunately some shops will take you for a ride as far as you will let them.
These are the same people that took 2 days to do my 30,000 mile Oil change and Service.... I dropped it off on my way to work (@7:30am) and had them come pick me up after work... still not ready... Had to get a hotel for the night then had them pick me up from the hotel and bring me to work and then pick me up from work the next day.... I still sat in the lobby until 6pm for it to be ready!!! Needless to say I have never gone back...
Don't go to Bayside either!!! just as slow... I would recomend if you MUST bring it to a dealer from Pascagoula, I'd bring it to Mark Dodge in Mobile... If your interested in someone to do the work that is not a dealer and does great work and charges less than a dealer (not much, but it is less) Bring it to Warran Automotive in Waveland, MS... He does all of my work and I have not had a problem... He also stands behind his work... He will also tell you when It's something he can't handle or if it's cheaper to have it done else where... (example... My Mom's Dodge Caravan, was stalling... she brought it to him and he found out it was a Body Module... That was something that dodge has to verify with their test equipment... He still has not replaced some of his equipment from the flood... So it was faster and cheaper to go to dodge so he directed her that way) He's Good people and has knowledgeable Mechanics, His diesel guy is qualified in Ford and Dodge, and getting his GM certification....
update: [Name Removed] Dodge refunded me 2K and said they could not and would not work on my truck anymore, refused me service. I dropped it off at [name removed] Dodge in [location removed]l. this morning and at 3:30pm today they called and told me the shop foreman was refusing to work on my truck because he didn't want to fix someone else's screwup. I will never buy another Chrysler product again in my life
Bring it to a good diesel shop for the repairs.. I am sure someone on here could make some recomendations of local shops? I could give you one if you were in the North East...
Good luck
Good luck
