Dead KDP - Can't torque crank pulley bolts!
...finally! Took me 7 hours (the crank seal really kicked my rear - I destroyed the new seal trying to get it on using the Cummins supplied starter - I had to put the old one back on using a rolled up plastic sleeve - hope it doesn't leak!)
Question! How do I torque the crank pulley bolts without a barring tool to hold the engine!? I'm fully reassembled, but don't want to drive without tightening those last 4 bolts! Please respond ASAP, I need to be up and running this morning!
maybe impact wrench with torque setting? when I work on my hub assembly and dont want the wheel to turn when remove axle nut I use the impact, same when I did flywheel bolts too to keep engine from turning
Got it!
....I reversed the old serpentine belt and made a "strap wrench" out of it, worked pretty slick....
- no leaks from the re-used crank seal - yet......
92smokin blacky
02-28-2011 02:36 PM
NoSparkplugs
02-26-2006 08:17 PM
