dead batteries and click noise
How old are your batteries? It might be a good idea to get your alternator checked as well. If the alternator is not charging it will just run your batteries down again. Definitly check your charging system.
The guy before me rebiult the starter will that click or not make a noise at all?
I just bought it a few weeks ago so im still learning alot i new that that is the noise it makes when batteries are dead but it was started and ran like a week before that i just thought it was wierd that they just whent dead.
This will be a VERY useful site for you:
http://www.dodgeram.org/support_pgs/diesel_ix.htm
1996 HP/Torque is here:
http://www.dodgeram.org/tech/dsl/Facts/96specs.html
180 hp/420 torque
180 hp/420 torque
thanks i charged them for a few hours yesterday and it started right up but then today it just was able to stary with like 11 volts could this be a bad connection somewhere that it is not holding a charge?
What does your voltmeter say when the truck is running? If it's a bit over 14 it's charging OK and the next test step would be to disconnect the batteries and let the truck sit for some days. Reconnect and start. If it has good voltage the batteries are ok and there is a drain on the system. (Start with simple stuff like lights, radio etc)
If it hasn't got good voltage- dead batteries.
HTH
AlpineRAM
HTH
AlpineRAM
Sleigher
03-23-2007 12:23 PM
cheapskate
19
12-27-2006 08:05 PM
PaulDaisy
12-02-2006 12:36 PM
