cylinder missfire
cylinder missfire
i am trying to figure this out ever since i put stage 5 jammers in truck cuts out or a cylinder miss only with the superchip tried every thing from two holley blue pumps with 25psi boost foolers do superchips work with big injectors or is it an injection pump problem but it runs fine without the superchip what would you do thank you
The fueling boxes and chips work with any injector. If you are only getting a miss with the superchip installed and turned on to call for more fuel or for modified timing, then it is likely that the injection pump is failing.
The pumps do not always generate an error code when the delivery valve timing shuttle begins to fail.
JOESHTRDDSL
05-05-2008 11:04 AM
