Cpk Trouble
Cpk Trouble
Well my CPK is obviously out i lose my tach and extra power when running down the highway. I got all the infomation on how to fix it. u know the usual remove starter and what not but did all that and there is no CPK there!!! So i went and called the local dodge dealership and they tol me on my truck 2001 2500 2WD the CPK is behind the ECM but ive never heard of this. Just wondering if there is any other sensor/switch/wire that could be loose or that i need to check.....
There is no Crankshaft Position Sensor on these. The tach is driven by a signal from the Camshaft Position Sensor, which is located below the VP44 on the back of the timing gear cover housing.
ridlangus123
12-30-2013 09:36 PM
