Clicking from Left Front Wheel while turning??
Hello All,
Yesterday I was bringing some yard waste to the back yard and while turning in 4 Hi I noticed some clicking from the Left front wheel. As I turned more it almost seemed to be binding up.
I jacked the truck up and checked the wheel hub by lifting and pushing pulling the tire but it does not seem to be loose. The wheel also spins pretty freely and I can't see anything wrong.
Any thoughts, ideas are appreciated!!
Help this is my only vehicle and if ot breaks down I am stuck. Also I can't afford to spend big bucks on it. Just bought a house and had my first child!
Thanks,
Mike
Thanks,
Mike
Re:Clicking from Left Front Wheel while turning??
When it's jacked up, leave it in 4 wheel drive, (just the one side off the ground) and try to rotate the tire back and forth. Look at the universal joint in the knuckle for movement/wear.
Too me it sounds like a worn/dry u-joint in the stub shaft.
Calm down a little, mine is a 99 and the binding at full lock appears to be normal, you have ujoints not light duty cv joints in your front end, the clicking may or may not be a worry, but if it is the u joint they are not all that expencive.
First of all thanks for the input dsldan and DRD.
I finally got a chance to jack the truck up today in a little better light and check out your suggestion DRD. The u-joint in the axle shaft does not look too bad, but I question whether the bearing may be bad?? While spinning the wheel backwards it spins free and then almost locks up and then clicks, then frees up again. It seems like there are at least two places where it is binding and clicking. It does not seem like the clicking is coming from the u-joint but more from the hub area.
Any new thoughts??
Does anyone have a written procedure for changing the axle u-joint and/or the wheel bearing??
Thanks Again,
Mike
Any new thoughts??
Thanks Again,
Mike
If the truck is in 4 wheel drive,in gear, the other 3 tires on the ground, you should not be able to spin the tire that's in the air. It will move only a little depending on the amount of drive train slop.
Hey DRD,
Sorry I jacked it up two different times. Once as you suggested in 4 wheel drive and checked the u-joint and it seemed fine. Then I drove it and disengaged 4-wheel and jacked up again and that is when I was spinning the tire.
Sorry for any confusion.
Any thoughts on what it might be??
Thanks Again,
Mike
Thanks Again,
Mike
That is when I noticed it first but it does click in 2 wheel also.
I can only hear it at slow speeds so I am not sure if it does it all the time.
If its stiff in one spot during a revolution it could very well be just a warped rotor and this could explain the clicking sound as the rotor turns its picking up the pad and then once past that spot it drops its again giving you the clicking sound that your hearing. Usually a bad wheel bearing will show up at highway speeds and its pretty hard to miss.
Good Luck
Jason
Good Luck
Jason
tndiesel
09-07-2011 12:56 AM
Timberman
08-18-2010 02:46 PM
hovisimo
06-16-2010 09:18 PM
silverbullet02
10-05-2009 12:16 PM
buldaawg
13
04-23-2008 09:17 PM
