changed fuel filter - no fuel at supply banjo
so is there a better/aftermarket lp i can get? i plan on adding alot to this thing for power and miliage, but no dragster. i still have to tow my rock buggy to competitions and drive the truck daily. i will have to get a stocker somewhere tomorrow, as my 24 hr autozone has no access to one for a week.
jeremy
jeremy
Administrator / Scooter Bum
A stock pump replacement will take ~45 minutes to an hour depending on how long your arms are.
plug your info here for the closest Cummins parts house.
http://wsl.cummins.com/ServiceLocato...servicelocator
The Dodge dealers will want $250-$300 for the exact same stock pump.
alright, heres my next worry...
please someone tell me the injector pump should still be safe. ive read when the lp goes, it sometimes takes the ip with it. im royally screwed if its done too.
jeremy
jeremy
After hearing what you guys said, I guess my lift pump must be bad too, I cant hear it when I bump the starter, but if i touch it I can feel vibration. Well I changed my fuel filter about a month ago, filled the canister with diesel fuel, then started it. It ran for a few seconds then died. So I cracked the banjo fitting at the injection pump, bumped the starter a few times, no fuel at the injection pump. So I just tried to start it, with the banjo fitting cracked, I cranked it over for about 30 seconds, check the banjo fitting, fuel it dripping out. So I tightened up the banjo at the IP, then I cracked injectors #3 and #4, no fuel came out. So I cranked it over for a few seconds then it started, I shut it down right away, went and checked the injectors and fuel was leaking out. So then I tightened the injectors, cranked it over and floored it, after a few seconds it started ran rough for a few seconds, and had been running like new ever since! So I dont know after that if my LP is bad or what, but that was my expirience. Thought it may help.
-Andy
-Andy
jeremy
jeremy
If you haven't experienced any of the other symptoms, dead peddle or hard starting, then you're probably ok, for now at least.
phox
please define "dead pedal". do you mean like nothing happening when pedal is depressed? as far as starting goes, it starts almost instantly - well it did.
Driving along, go to accellerate, and nothing happens, foot goes to floor but truck continues along at the same speed.
Pump the pedal a couple times, engine burps some smoke then works like nothing was ever wrong, dead peddle.
phox
phox
I think it would be a wise move to check your fuel pressure before you buy a LP. You need the hose that screws onto the VP-44 schraeder valve and a 0-30 psi pressure guage
how would i have a pressure reading if the system is not primed? of course i am not looking on the truck to see the shrader. as i would guess, i have run all the fuel out of the system after it ran and then cut off.
Mopar makes an up dated fuel pump
That will probably out perform most after market fuel pumps,because its now in the tank It replaces the existing fuel tank module.It includes a pump module a harness and relay and a block of plate that replaces the old lift pump.
209trucker
09-22-2013 11:35 AM
Rue
02-02-2009 02:43 PM
Big Smoky
03-06-2006 10:47 PM
KATOOM
10-22-2004 11:33 PM
