a/c vent?/cruise cont.
Old 06-05-2005 | 03:38 PM
tinman1911's Avatar
my a/c and heat only blows out of the defrost and floor vents switch is fine could it be a vacume line? and also my cruise control doesnt work light doesnt even come on could these be related?
Old 06-05-2005 | 04:15 PM
fschiola's Avatar
Yes, you have a vacuum leak somewhere. Check all of your lines and that should clear up your problem. Also check these.
Here
And here
Old 06-05-2005 | 10:39 PM
Stamey's Avatar
I'd say you are experiencing what I just went through on my 96. It was a bad actuator for the vents, and the vacuum hose to the cruise control servo was eaten up by battery acid (it's under the left battery).
Both of these problems though, could be caused by the lack of a check valve in the vacuum line from the vacuum pump. This happened on some trucks in 1996. Mine was affected, and oil caused the vent actuator diaphram failure.
Here is the TSB: http://dodgeram.info/tsb/1996/24-16-96.htm
Chris
DieselSmith
12-06-2006 05:51 PM
iker42
11-16-2006 12:14 PM
broncobilly
11-14-2006 08:24 PM
big jimmy
01-09-2006 04:50 PM
Quick Reply: a/c vent?/cruise cont.
