boost gauge install problems
Hey guys, i have aautometer triple pillar i just put in my 05 and everthing is working but the boost. i drilled and tapped the aluminum phellum for 1/8 npt and put tape on fittings and connected the hose with no results cant get gauge to move. I cant figure out whats up? all suggestions appreciated. Roger
If you're trying to get boost while sitting still and reving the engine, you won't see any.
Get on the road, and stomp on the loud pedal.
If you're not seeing Boost while on the road, you have a blockage, or a massive leak.
Originally Posted by rog1215
I did the stomp and still no boost, i will go back and check for leaks or blockage, thanks
Did you over tighten the connections and collapse the tubing?
i have reulated air and i will test at 25 psi the connections were crushed the first time and i have 4 more i bought yesterday. How tight do make these before they crush the line but still seal?????
Well i found a crimp and that fixed it when i put a new hose on. The question is these readings, I can cruise at 60 and only have about 4-5 lbs boost. if i get on it it will go up to 35 and then settle back down to 3-5 do these #s sound right for a stock 05
Thanks for the help guys. Now i am waiting on my quadzilla tow box for my trip to yellowstone in june, i will be pulling a 35" toy hauler with 2 harleys in the back, and i think i have covered all the bases my wallet will allow at this time. Next up when i get back will be improved exhaust and intake. Roger
