Attempted Steal..Need Help
Some one tried to steal my wifes Gen3 truck (its a gas truck) I know boo boo boo, but we didnt need 2 diesels in the family right now. What I need to know from you gen3 guys is, is it possible to open the power distribution center to rewire the the starter relay. I have made a starter kill system up with a momentary contact switch and a couple of relays. I need to to take the fuse and relay part of the distribution center out so that I tap into a spare relay hole. Is this possible? If not what is the point of have blank relay spaces if I cannot gain access to them? Any Ideas?
Thank You!!!!
Thank You!!!!
Even easier, if it's a manual add a switch in series with the clutch safety switch.
If it's an auto add a switch where the jumper wire that bypasses the missing switch is located.
if its an auto toss in a switch in series with the transmision/ brake interaface. truck will start but will not come out of park...... folow me on that one?
But the idea is sure good.. Seen a ford van locked up and couldn't move because the tail light fuse blow out...
11-21-2008 01:42 PM
mkivbren
03-20-2007 07:30 PM
rickkari0304
02-06-2007 01:12 PM
