adjusting fuel shutoff solenoid
Hello all,
I need to adjust my shutoff solenoid. As it sits its not opening all the way it appears. the pump arm will eaisly go down to a point then the last bit is heavily spring loaded, my shut off is pushing it down into this point, on full open it short probably 15% of its upward travel. do I set the adj to where its full open and it closes as far as the solenoid goes?
out of commision need help
Thanks
apache.
Thanks
apache.
hey apache
here a link to adjust the shutoff solenoid
http://dodgeram.org/tech/dsl/trouble..._solenoid.html
when i replaced mine i just mess with it till it work
not very hi-tech but it works
bruce
bruce
Might have to recheck , before I read your reply I pulled the shut off lever up snugly and adjusted the rod till they matched length with just a tad of slop. I just wanted to make sure it was up all the way.
Thank You.
Thank You.
