ABS LIGHT ON HOW TO CLEAR CODES???
Old 03-31-2003 | 07:45 AM
hellotbone's Avatar
Hey guys changed the balljoints on my truck and pushed the caliper back and didn't know but now the light is on. How do I clear the codes from the computer?<br><br><br>
Old 03-31-2003 | 07:53 AM
Smokee's Avatar
Re:ABS LIGHT ON HOW TO CLEAR CODES???
Jamie, you probably pushed crud into the balancing(?) valve because you didn't loosen the bleed screw. I did the same thing.<br>On mine, the light just went out after a few days. A mechanic tried to clear the codes, but on my truck, at least, that didn't work.<br><br>BTW, the ABS light has decided to come on again!!!! No idea why.<br>george
Old 03-31-2003 | 07:56 AM
hellotbone's Avatar
Thanks smokey thats what happened!
Old 04-01-2003 | 04:11 PM
wildolman's Avatar
Hey there. On mine when I had the cables off for about 30 mins to reset the apps my codes disappeared,the bad ones came right back. But don't know wether that will work for the ABS though.Good luck.
fitzydog
21
10-11-2017 01:09 PM
Joey-D
12-12-2011 01:52 PM
BigBore050
03-10-2010 12:46 AM
sssmaly
07-13-2007 01:57 PM
mr T
02-24-2007 07:42 AM
