ABS/Brake light stay on HELP!!!
I have a 1997 Dodge 3500 diesel with only 69,000 miles on it. One day the lights came on and have been on since. Its driving me crazy! Ive checked fuses and see no problem. Any advice is greatly apreciated.
Check your master cylinder brake fluid level - it's probably low.
Had this happen many times on my '98...
If it is low, check your front pads; when they get thinner the pistons come out further in the bores & increase the minimum fluid volume.
yah well i got it and it was fine and all the sudden it was acting up. a truck with only this many miles shouldnt have any major problems i dont think. but thanks for the comment. I am very proud of it as long as I dont tell anyone im showing off to about the problem.
There's some related info at this link, codman, just wish I'd get off my own dead fanny and fix my own. Too many projects...
https://www.dieseltruckresource.com/...19&postcount=2
Jimmied
Jimmied
Did several at the dodge dealer with this problem, rear wheel speed sensor on top of rear axle. Usually on the service lane at the dealer you would jump in and start out to the shop and see the abs/brake light on and have it diag'd before you got to your stall. Simple check with the scan tool would reveal the code for the rear wheel speed sensor. Go to an autozone and have them check codes, see if it is the sensor and then replace it.
Originally Posted by codman
No the tach seams to be fine. the truck operates the same except maybe the brakes are a little touchy.
I assumed in your 1st post you checked the ABS relay as well as the fuses...
that'd be my second look if you haven't already. Pull the fuse/relay center cover off and swap for a known good relay (there's lots to choose from!) & test drive.
Your touchy brakes gave it away...
Ha! My 97 3500 is doing exact same thing. But I have 180,000 mi. on mine.
1. ABS light on
2. "Brake" light on
3. Air Bag light on
4. Brakes very touchy especially when humidity is high or rain, locks up all wheels.
The brake indicator lights came on intermittently at first, then after a couple weeks it became solid, then about 2 weeks later the Air Bag light came on solid.
Shop checked clockspring, tests okay.
Would the rear-axle speed sensor affect all these things?
My shop here is puzzled, they got no codes. Maybe I'll get AutoZone to pull codes.
Is there a relationship between the Air Bag and Brakes/ABS?
I gotta get this fixed so I can go on vacation pulling my 30' trailer this weekend!
thanks.
1. ABS light on
2. "Brake" light on
3. Air Bag light on
thanks.
About four years ago, I took mine in to the local idiots for the recalls. I didn't make it out of the parking lot- the brake and anti-lock lights were on. Funny, they weren't doing it before I left the truck there. Anyway, the brainiacs spent a couple of days, and called "Star" a couple of times before they finally figured out there was a hole "rubbed" in that line. They "fixed" it by slipping a two foot piece of hose over the line ends to take up about 2 inches they cut out!! They just looped it around the master cylinder. What craftsmanship.
Later, I have found out they only did part of each of the recalls, not even installing the parts that come in the kits. If I could find an honest Chrysler dealer, I'd have them verify this to "Star" and let these guys explain why they charged full hours and parts for the recalls.
I also have had to add a small zip-tie to the little rubber boot on the top of this vacuum line since the oil from the vacuum pump has softened and expanded it.
