97 3500 Cummins leaky oil pan drain plug
Sometimes if the plug has been overtightened the pan will get distorted and no longer seal.
Best bet is to drain your oil, clean the surface well and use RTV to permanently seal on one of the many oil drain valves available.
Either that or replace the pan.
Will the RTV cure in the oil residue?? Theres no way youll be able to clean off all the oil.
You could try putting an o-ring under the new drain plug.
A vendor just brought in a great product yesterday for removing oil. It is a bacteria that actually eats the oil and leaves a very clean surface. We tried RTV on an oil spot after using the stuff and it bonded really well. I don't know what is costs yet, but it came from Motion Industries.
Get a nylon gasket from this company:
http://www.cgenterprises.com/drain_plugs.htm
Your Cummins uses the 22 mm size. Remove the old rubber one, and replace it with the nylon one (#2008W).
They are a great source for replacement drain plugs, magnetic as well.
Originally Posted by mkrenn
I've used teflon tape. Works everytime. Used it on my personal rig and work trucks. Cheap too!
smokinram99
07-28-2009 10:07 PM
mstep3
06-29-2009 03:15 PM
Mechanos
19
01-31-2006 10:08 PM
03CTDCO
06-15-2005 11:11 AM
