7 Pole RV Plug (wiring project this afternoon)
Guys;
My 7 pole plug was extremely coroded, and had a few broken poles when I bought the truck.
I went to wal-mart and just purchased a new 7 pole plug. Get home,.....and find on the back of my factory plug, I've got 9 wires going into the back of the old plug. All seemingly soldered into the factory plug.
I snipped em all off with my side cutters, and proceded to wire my new plug in. I've run into a hitch however,.... using a test light and checking each of the 9 wires by hand, I've found the colors do not coordinate with the colors on the back of my new plug. No big deal, because I've found a chart which tells me which pole each wire goes too. I now have my tail lights, rt, lt, and rev light wired in. My trouble is that I have 5 wires remaining that I dont have a clue what to do with. I have a red wire that is continuosly hot, a blue wire, and a couple brownish wires remaining. Not too mention, my trailer lights are not working? I assume one of my brown wires is a ground,.......but have tried wiring each of the 2-3 brown wires into my plug, and none have produced any results.
Clear as mud? LOL.
Any insight ?
Thanks.
Clear as mud? LOL.
Any insight ?
Thanks.
this is how mine is so i hope it works for you ,
red=12v charging - top right terminal
white=ground - bottom left terminal
yellow=left turn - middle left terminal
green=right turn - middle right terminal
brown=park lights - top left terminal
blue=reverse lights - large middle
i know you said you had a diagram to go off of, just giving you something to cross reffrence. i also have somewhere written down the trucks stock color wires to splice into, to wire the 7 pole up. i will look for it.
Thanks for the help Mark! I found that I had the plug wired backwards.....or upside down. I switched everything around, and it worked fine.
Thanks again!!
Thanks again!!
7 pin plug
Now that you finished it buy a container of Vaseline and fill it full this will stop MOST of the corrosion mine has been good for 5 years now so far and have just plugged it in and away we go ( just broken lights).
Actually, I sprayed a good coat of electrical anti-corrosion over the terminals,.....tightened the collar gromet, and then filled the back collar with silicone. Smoothed her out nice and pretty.......hopefully wont have to bother with it again for a few years.
Thanks for the tips!
RonsRig
25
01-03-2007 02:14 AM
1qckdodge
13
08-28-2006 11:35 PM
OWN BAJA
04-23-2006 06:42 AM
