68RFE lost 5th and 6th gear
It seems to be fine 1-4 then stays in 4th If I get it up to 2800+ rpms then shift it manually it will go to 5th and 6th for a split second,it kind of shuffle between them then goes back to 4th.I just dropped the pan the fluid looks and smells ok,no metal shavings just a fine mist on the magnet.Anyone ever have this problem or know what the fix is.Thanks
Stealth Mode
11-23-2005 07:52 AM
