6 speed man trans fluid
Help,
I've drained all the fluid out of the transmission, picked up Mopar ATF+4 at the dodge dealer last week. I told him what I had and that's what he gave me. But the plate on the PTO cover says to ONLY Use TEXACO STF 1874.
Is the Mopar ATF+4 fine, or am I stuck until I find something else
THanks
2001, 2500, 4x4, 6-speed manual.
THanks
I say take it back. Its the wrong stuff and your parts guy is on crack.
The specs for the fluid you are supposed to use is found here:
http://www.dodgeram.org/tech/transmi...5600_spec.html
Many people have used Redline MTL, Royal Purple, Amsoil with great success.
I've been using ATF+4 in mine since I've had it and have never had a problem out of my 6 speed. ATF+4 is what it is supposed to have in it. Any dealer will tell you that. Have you looked to see if TEXACO STF 1874 is the equivalent to ATF+4? TEXACO STF 1874 is paraffin based oil. It doesn't flow as well in the cold as the synthetic ATF+4. That means in cold weather your 6 speed will not want to shift as well until it warms up. My 06 has over 180k on it using only ATF+4. With today’s close mess tranny's they need low viscosity oil. Either will work though. The TEXACO STF 1874 is what was used prior to ATF+4 in the 5 speeds. I could be wrong on that but I'm sure someone will look it up and correct me if I am.
Mark
Mark
Help,
THanks
THanks
Valvoline ATF+4® is a high-quality synthetic transmission fluid specifically engineered to protect and prolong the life of Chrysler automatic transmissions
Replaces ATF+3®
Excellent low and high temperature performance
Controls friction and provides smooth shift performance
Superior anti-wear and anti-oxidation properties
Contains additive to reduce foaming
Testimonials
Be the first to submit a testimonial!
Product Specs
Meets Mopar Standard MS-9602
Meets Mopar Type 7176®
Meets Mopar ATF +2® Type 7176
Meets Mopar ATF +3
Meets Mopar ATF +4
ATF+4 goes in the new G56 transmission. You should hav ethe NV5600 six speed. Do not put ATF+4 in the NV5600! You will roast the transmission. Check your owners manual for the proper fluid.
Mark
Mark
Mark, your sig says you have an auto....
Use a GL4 synthetic in the NV5600. The recommended fluids, Redline MTL, Texaco 1874, etc., are all rated GL4. (Along the same lines, don't use these GL4 fluids in your axles....)
reidry
15
12-20-2005 09:35 PM
Lsufan78
05-24-2004 12:25 AM
