2nd gen headlamp switch
Already had the switch done once under warranty. Sure enough, this one is going too. This morning, had headlights, no interior.
Will they fix it twice, or at least give me the switch/
Either way, You need to do 2 things once you get the new switch.
1. Don't dim you dash lights. When you dim them down, the rheostat gets pretty hot in there, and the theory is that over time it burns the switch up. Some people have drilled a hole in the A/C duct so it will blow cool air on the switch.
2. If you tow alot, take the load of your trailer running lights off the switch by running a seperate 12v line to a toggle switch. This will help.
Good Luck.
Shilohman
08-27-2010 12:14 PM
royta
01-17-2009 03:25 PM
njmaier
04-26-2005 09:13 AM
