2006 Dodge Ram Turbo Diesel 4x4 Oil comming out of exhaust
I was stopped at a light, I went to accelerate and a loud sound like air coming out of a tire very fast and very loud erupted. right after that the truck would only get up to 15 MPH. I then saw a huge cloud of smoke come out from the back of my truck. Mind you with 170,000 miles i was surprised.
I got the truck towed to a mechanic and he told me the motor blew. I called a dealership and they want $700.00 up front just to tear it down and diagnose it. I made some calls and researched on line and have found that in some cases The Turbo blew out, this makes sense it has the same symptoms.
Please help me with your ideas.
Thank you all in advance
Texas Pete
Texas Pete
Cummins Guru
I would pull the hose that goes to the intercooler and check if any oil is there. If there is oil then the turbo needs to be replaced and the intercooler cleaned out since it is filled with oil now. I would use a detergent like cascade with water only. Donot use anything flamable since it could be drawn into engine and cause engine damage or diesel runaway.
Cummins Guru
That diag amount seems pretty high. Unless you have a dead cylinder with low compression a tear down isn't needed. A starscan that dealers use can locate problem and pull any codes much faster. I usually charge one hour to diag. If compression test is needed usually charge a little more. A turbo failure can be checked in less then one hour. Replacing turbo and cleaning intercooler could be expensive.
Intercooler
BigIron Thank you!!!
I will check it out, the inter cooler will have to be taken off of the truck and cleaned out this way correct, it can not be flushed will mounted right? Also the air filter oil would have gotten inside right?
Thanks so much
Texas
Thanks so much
Texas
K.i.s.s.
Um.... this sounds just like when I had an intercooler boot split. Deep Poomp! and whoosh, lots of smoke, and no power. I have gauges, so it was easy to see NO boost, and very high EGTs. Idle seemed completely normal. I pulled the hose from the air cleaner to the turbo, checked that there wasn't a bunch of slop in the turbo, spun it with my finger etc.. All looked fine, then I looked down and saw the blow-out in the intercooler boot. One new boot, cheap fix.
HTH
HTH
My bearings blew out on my turbo due to oil dilution from a leaking injector. Check your oil level and see if it is above nominal. When the turbo bearings fail it is very loud and sounds like a steering pump whine on steroids. 1st the turbo sound drops in frequency from a whistle to a whine, and then a growl. At this point you will have very little power. Smoke will billow out of the exhaust if you press the accelerator. Replacing one injector and a turbo cost about $3300.00.
fmz
18
05-27-2017 05:23 AM
Captain Dean
04-30-2006 11:01 AM
