2003 Dodge 2500 Won't Start Warm
Old 03-01-2008 | 03:38 PM
bbrusseau's Avatar
Question 2003 Dodge 2500 Won't Start Warm
We resently had the lift pump replaced, after that we could smell fuel, it will start cold (a little hard), it will start hot, not warm. We took it to the next place, the first a dealer would not stand behind his work, and the 2nd replaced the Cumins computer for a mere $2800. It is just a bad as before. Any suggestions will help greatly.
Old 03-01-2008 | 04:20 PM
Busboy's Avatar
You must have a fuel leak and it's letting air into the system when its shut down. Have a look around the lift pump.
Old 03-01-2008 | 04:34 PM
bbrusseau's Avatar
Makes sense, Thanks!!
Old 03-01-2008 | 05:02 PM
Dwitt0187's Avatar
start the truck and look under the engine where the blow by tube is and see if there is what looks like smoke coming out if it. if there is put your hand done by it and then smell your hand if it smells like the diesel fuel then you have a injector blown. check the oil to see if it is over full.
Old 03-01-2008 | 08:16 PM
bbrusseau's Avatar
I will try that. I see your from Georgetown, I use to live in Lexington. Thanks for the advise.
Old 03-04-2008 | 07:33 PM
Dwitt0187's Avatar
did you have any luck with your problem? do you still live in the area?
Root
16
05-04-2016 05:53 PM
Bugaboobill
10-17-2010 07:32 PM
Dodge Mack
10-12-2009 05:38 PM
joebishop23
10-29-2007 10:19 AM
Primetime
02-15-2005 05:58 PM
Quick Reply: 2003 Dodge 2500 Won't Start Warm
