1250 EGT just driving down the road
This is what hapened I pulled out in front of some one first thing in the mournig (cold engine). Turbo started wining no boost turned around went home less than a mile. Pulled tubo off the turbine had some play in it and rubing the housing. Put a super B on it with 4" exhust. now ever time I drive it runs at 1000 deg plus EGT's. I also noticed the intake air temp is 130. I check all the iner cooler boot the look good. Any sugestions?
Administrator/Jarhead
Chech your connections on your EGT probe/gauge. I would disconnect everything, scrub the contacts down with a small wire brush, throw a little dielectric grease on there, and see what you have. Make sure you check any grounds if you have a power source hooked up.
hth...
hth...
bigwheels94
41
05-27-2010 07:38 AM
kuhkuhkyle
25
05-08-2008 06:08 AM
BROKER
02-27-2006 05:18 PM
Zino
16
08-06-2003 07:04 PM
