#11 plate with 3gsk?
I ordered a 3gsk spring kit for my 98 12v and the P.O. told me that it had a #10 plate. So I get the AFC housing off and it has a #11. So I'm reading the directions and it says not to install unless you run a #10???? says it will run worse than stock, opinions? has anyone run the #11 with a 3gsk? should I just put it back together and grind my stock plate? need my truck for work and it's down right now. One more question, if I were to put it together without the 3gsk could I slide the 11 all the way foreward until I could grind my plate?
big jimmy
02-15-2006 03:24 PM
royta
09-16-2005 04:31 PM
crossy
03-28-2005 06:12 PM
