05 Cummins, Cluster not working, no start.
Hi,
I have a 05 2500 automatic with a ISB. Truck cranking fine but doesn't start. All needle in the instrument cluster is not working. I'm unable to scan it with my Snap-On Modis scanner.
The 3 red wire on the ECU has 12V and 3 ground (Black) is okay.
How the ECU is switching power on ? Instrument Cluster ? Ignition Switch ? Key Sentry Anti-Theft ? ... ?
Regards
Dominic
Regards
Dominic
I tried another 05 ECU, cluster working, no start because ECU has not the same ESN from the Cluster I think.
We put back the original ECU, cluster work and truck run, shut it down and cluster was not working anymore and truck will not run but crank.
Truck was on warranty and Excellence Dodge said it was the clutch fan circuit that was short ....
We are waiting for more information and if the truck still ran hhehehe
Sleigher
05-04-2017 02:12 PM
treeeman00
06-13-2012 07:57 AM
squarenose
09-23-2011 06:42 PM
