04.5 poping (missing sound) under load
04.5 H.O. missing or poping under load black smoke for a second. Got worse 2nd day lost power for 3 seconds. Slowing down everything was fine. Fuel Filter? Just found out fuel filter is stock 50K miles.
edge W/Attitude level 3. APF intake. Straight Pipe
Location: Climax, MI (between battlecreek and kalamazoo)
What do you have done to the truck? it would help if you could fill in your sig. if it is turned up much i would say you are draining the rail.
OK. I just changed the Fuel Filter and all seems well. I ran it hard under load towing 5TH wheel. It's still showing a p1249 code, any advice? How can the code be reset? Can a clogged fuel filter cause a code P1249?
took the truck to have a scan done and remove the codes. Is this somthing I need to address with a Cummins dealer? Can the codes be a result of clogged fuel filter? truck seams to run fine now that filter has been replaced.
childitch
04-02-2007 08:47 PM
12valve
30
12-25-2005 10:01 AM
