03 dodge wont start help!!!!
i have an 03 dodge 2500 with edge aditude intake/exaust and just resiently put methenol on.
i pulled up to mcdonalds and shut it off to hear the lady and order when i go to start it up it just cranks
ive have fuel to the filter and to the motor i crack an injection line to check i think its electric its crankin like a champ
i disconected all of the egde and meth and it still wont start
the main code im consurned about is p2146 witch is fuel injector group1 supply voltage circuit
any idea or any think please chime in
Look at the connection for the alcohol/water injector valve. I suspect you tapped into the fuel injection feed pump voltage line, and that will draw down the voltage enough to shut down the feed pump and stop fueling. It can also blow the fuse.
Trace back to the power distribution center and check your fuses for the injection system.
If that is not it, make sure your alcohol/water system is injecting downstream of the sensor array. Water on the sensors will shut down the primary fueling circuit. Also, disconnect the Edge until you sort out the problem.
Originally Posted by Copenhagenjunkie
Are you sure the code is not p0214, the kiss of death for the vp-44.
got nothin
hey rcv all the fuses have been checked my next step will be a rail preasure test my meth is hooked up to my intake and it controled by my boost right now i have it all disconnected.
the code p2146-fuel injector group 1 supply voltage curcuit what could cause that sensor somin i got a feelin that has somin thin to do with it
any more ideas keep em comming i apreshate the help already
TNDODGE
09-13-2012 01:38 PM
Stroked-Z
10-04-2008 11:28 AM
griggs43
01-09-2006 04:34 AM
