01, wont turn over fass running all the time
Went to start today and check engine light came on, winding noise with brake depresed and increased rpm. I had it run for 5 minutes them tried to re-start 4 hrs later. The fass is pumping nonstop and it will not turn over. INJ pmp, Vac pmp? I am lost
The Fass is supposed to run a few seconds and then shut off. To much pressure and it won't start. You and turn key on and then off to get it to run 20-30 seconds and then shut off. It will throw a code it it runs continuously when trying to start
I have not checked the codes yet.The fass filters are always changed every 20000 miles 5ooo miles ago when low sulfer fuel acted like a solvent and cleaned my tank, 4 filters in 2 days. I pulled the fule line at the ip and the fass is pushing good no air. WAIT IT DOES TURN OVER A "LITTLE LIKE ITS A DEAD BATTERY, LIKE MY CYLINDERS ARE LOADED UP. Dont have a reader cant check the codes??? what to check next? Thanks so far everyone for the input
try jump starting it too.
it might pay to check the oil and charge/jumpstart. if the oil is up or stinky...you have problems, if the batts are down it could be your problem, or at least some of it.
I would have your batteries load tested.
SYMPTOM
P1291-NO TEMPERATURE RISE SEEN FROM INTAKE AIR HEATERS
that's what I found on that code, if the grid heaters are not coming on then it may be from weak batteries.
SYMPTOM
bostongsx
12-14-2010 07:41 AM
