01' 3500 drivers side wheel bearing/hub assembly
left front wheel bearing went out and i can only get the whole hub assembly from a dearship. anybody have one or knows where to get one . 01' 3500 4x4 dually i live in virginia beach
Thats the way they all come, as an assembly. Check with Napa and other parts stores, but make sure you get a Timken brand bearing. There are a few cheap knock-offs of much lower quality available.
Jim
Jim
From: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
Hub assy will run you ~$300. Dealer only. Comes with ABS sensor, studs installed, and axle nut.
At least here, if you're military, you'll get a 20% discount.
itonlyhurtsforalittlewhileShortround out
yeah i priced the hub assembly in culpeper, va and they would sell it to me at cost $288. i was hoping that someone might know if there were any junkyards or wholesaler that might would have one.
the 95 would not do you a whole bunch of good, as it did not have front ABS. this is the difference in the front hubs.
I know, I just put a new left front on my 01, at the cost of $500.81 CDN. glad I didn't need to have it installed. jeez.
just another dealer only part. Even the parts guy said he was embarassed to charge that much for a wheel bearing assembly. Oh well, life goes on.
Good luck in finding aftermarket stuff.
If you have abs you can get them from discount auto parts at http://www.discountautoparts.com/ You can get the hubs for 250
yeah i figured i would have to use a dealer for the hub. if you are paying more than $400 you're getting robbed. dealer wholesale is $288 and your cost should be about $365 or so, no more than $400
Prodart440
05-17-2012 02:31 PM
Mcmopar
06-13-2005 07:34 PM
