View Poll Results: Where does your truck leak from?
Timing Case
17.74%
Rear Main
19.35%
Oil Pan
33.87%
Valve Cover
19.35%
Turbo Return Line
2.42%
Turbo
2.42%
Front Seal
21.77%
Dipstick Tube
7.26%
Can't Find It!
26.61%
Other... (Specify)
39.52%
Multiple Choice Poll. Voters: 124. You may not vote on this poll
Where does your truck leak from (check all that apply)
Old 10-29-2006, 12:14 AM
  #31
westcoaster's Avatar
Originally Posted by Jim Lane
If I try to fill it past when it clicks off it will leak down the sides of the fuel tank from somewhere on the top of the tank, I have a new grommet to replace when I get around to dropping my tank for the overflow valve but I think it is the nut on top of the sender.
But it hasn’t leaked in a while since I have not been able to top op my tank lately.
There is a slight leak from the transmission cooler line by the pan.
The biggest leak is the fuel; it seems to leak down by every 3rd. day costing me another $60.00 to fill it back up.
If something leaks I fix it so it does not eat up my driveway.
Jim
My '93 did the same thing (fuel tank) If I recall correctly that was "normal" for that tank.
Old 10-29-2006, 04:20 AM
  #32
Jim Lane's Avatar
I checked with the service department at Dodge and they said it is the vent and there was a bulletin to relocate it up higher into the body but I do not think that is where it is leaking from. I think it is coming from the big nut or at least the gasket on top of the tank. When it leaks it comes pouring out onto the ground and by the time you see it you already poured about $3.00 onto the ground.
It is not where you can see it if you get under the truck but if you feel around on top of the tank it is all wet. When I had it in the body shop they had the bed off and they said I could come by and fix it but I was at the other end of town so I missed out on the opportunity.
As long as I only put in $50.00 every 3rd or 4th day it keeps it just below the full and it doesn’t leak.
It is kinda embarrassing because it usually happens when someone is admiring the truck then it puddles onto the ground.
I just usually take the nozzle out and tap it on the ground a few times and say “I hate these stupid leaking nozzles” then go look for some sand to throw on the mess.
Jim
Old 10-29-2006, 07:24 AM
  #33
v8440's Avatar
The '06 does not leak at all. The '98 leaks somewhere, I think from the vacuum pump, but I'm not sure.
Old 10-29-2006, 01:55 PM
  #34
XLR8R's Avatar
My truck doesn't leak at all - should I be concerned?
Also, I've noticed when I drive more the diesel evaporates faster...
Or maybe there's an internal leak?
Old 10-29-2006, 08:21 PM
  #35
Mopar440_6's Avatar
I voted "Can't Find It" since the dang thing leaks everywhere. I'm suprised if that thing holds any fluid in for more than a week. I've also noticed a serious loss of fuel every time I push the long, skinny pedal down to the floor....
Old 10-29-2006, 11:56 PM
  #36
H2SRDMB's Avatar
no leaks anymore... fixxed the fuel leak from the water seperator on friday.. but i know i will get more..
Old 10-30-2006, 12:25 AM
  #37
windyr's Avatar
No leaks at all ......yet!
Jim b
Old 10-30-2006, 12:53 PM
  #38
TORQUE's Avatar
The only leak I have from engine(now 250,000kms) is an odd drop from blowby hose.
Old 10-30-2006, 01:14 PM
  #39
4x4dually's Avatar
So, since the "oil pan" takes number one (except for the 'other' category) does anyone have a fix for that? How hard is it to replace the gaskets? Do I even want to try? I have torqued all the bolts and it leaks pretty much on the entire rear half of it. Suggestions?
Old 10-30-2006, 09:33 PM
  #40
DTR's Cow Boss
DodgeCowboy's Avatar
Jory looking at that cross member tempts me to dry the pan off and red rtv the whole darn thing were she sits ROFL
Old 10-30-2006, 09:50 PM
  #41
truckjunkie's Avatar
Um - where's the 'No Leaks' option in the poll?
Old 10-30-2006, 09:53 PM
  #42
XLR8R's Avatar
Jory - are you sure that's a leak?
I thought it was an External Lubrication System!
One day I'll have to retrofit an ELS on my truck...
Old 10-30-2006, 09:54 PM
  #43
DTR's Cow Boss
XLR8R I am still thinking its just sweating from all that horse power
  #44
XLR8R's Avatar
If it's not leaking, you haven't broken it in yet!
... must still be on your first 100K miles...
Old 10-30-2006, 09:56 PM
  #45
XLR8R's Avatar
Would that be the hayburners on the GN or the ponies under the hood?
Quick Reply: Where does your truck leak from (check all that apply)
