When does Bio Diesel make sense?
Old 04-19-2005 | 02:09 PM
  #61
Childofthewind's Avatar
Originally posted by RickG
I didn't have time to check all the replies but wondered if anyone tried the kits with heated tanks to use 100% used straight vegetable oil . When was the post about biodiesel in TX made ? I've seen ***** Nelson's boidiesel selling North of Dallas . As for the poster saying fuel won't affect warranty ... how about when gas was accidently put in then run ??
The warranty question was discussed here:
https://www.dieseltruckresource.com/...threadid=65932
The point is the manufacturers warranty has never covered problems caused by out of spec fuel. If you put bad fuel in it is the fuel supplier you need to deal with. If you put the wrong thing in the tank it is your problem, if that caused a failure.
Biodiesel is ASTM spec'd and EPA approved, has been well tested and works with no modifications to your vehicle. SVO (straight vegetable oil) isn't any of these. It is experimental and is likely to leave deposits that will shorten engine life.
thumper
05-28-2007 06:19 PM
kc8ksg
05-31-2006 09:05 PM
piperca
05-29-2006 01:29 PM
Chinger
03-27-2006 12:45 AM
cginwyo
02-09-2005 08:47 AM
Quick Reply: When does Bio Diesel make sense?
