What shuts off a diesel engine?
Like the subject reads. I was just up visiting my folkes this weekend and my dad has 3, 17hp diesel engines he's converting for generators. He will give me one if he can figure out how to shut them off. These engines were stripped from commercial floor buffing equipment. 2 new one used. He's sure he can get them to run but is concerned on how to shut them off without the shutoff switch from the commercial equipment, not included with the purchase. We thought about a fuel shutoff but that doesn't sound right or good for the engines. What shuts off a CTD or diesel engine besides the key.
Thanks.
P.S.
For anyone that was following the Black Tank thread, never use baby wipes in your camper toilet. My 4yr daughter thought since it has a potty she could use her wipes like at home, NOPE.
Bill.
Thanks.
P.S.
Bill.
Thanks for the fast reply.
Wow, we thought about that but without a high pressure pump that would be hard to start. Looks like we'll have to figure a priming pump or bubble.
Bill.
Bill.
Air shutoff works fine too, if rigging a fuel cutoff is impractical. Just a flapper over the intake will kill it. Could be manual, cable, or solenoid operated.
Edit - the shutdown solenoid is probably part of the engine, all you will need is a switch. The solenoid will either stop off fuel to the high pressure plunger or will move the fuel rack to zero fuel. It will not cause the engine to lose prime.
Re: What shuts off a diesel engine?
Re: Re: What shuts off a diesel engine?
Originally posted by bulabula
How did the floor buffer workers shut them down? Who manufactured the engines? - Send them an email. Might be an answer in there for you.
Bill.
A customer of ours that's in your town is a dealer and services propane powered floor buffers. The name of the company is Easy Buff. They may know something about the machines that your engines came from. Their phone # is (719) 522-0207.
best guess is look at the injection pump, I dont even knwo what were looking at here but most of them have a shut off on them. Which is how they shut off. The silinoid could be gone, Just take a look at the lever/plunger in on it. Then you should figure it out.
I remember reading a post here months ago about someones CTD not shutting down with the key. Could you actually shut one down by taking the air hose off the turbo and say put a metal plate over the turbo to block the air intake?....just curious.
(Referring to Kubota's from memory, so your mileage may vary)
Bill; Many of the small 2cyl+ diesels have a speed control lever with two high and low rpm limit-stop screws, a separate fuel shutoff lever arm AND a small cover plate on the rear of the Inj Pump/Governor assy where an optional 12v fuel cutoff solenoid can be fitted.. Like WANNADIESEL said, your engines MAY already have one of these attached. If so, they can sometimes be seen as a short squatty cylinder about the size of a fat pillbottle with 2 or 3 wires coming out.
If these little engines in their previous life had electric start, they almost certainly had a way to shut them down just as easily.
Take a good look at the inj pump and governor and see if it may actually have a SD solenoid already there.. If it does, you are in luck!
By the way, what brand and model engine? How many cyls?
Keith
Keith
Bill, here is a link to a fuel S/D solenoid for a 4banger Kubota
http://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WDVW
Notice how small it is in relation to the 3 terminal connector!
K.
K.
