Sponsored by:
Sponsored by: CARiD
View Poll Results: What oil filter do you use?
Amsoil EaO80 or Donaldson ELF7349
16
15.09%
Fleetguard LF16035 (Stratapore)
42
39.62%
Fleetguard LF3972 (OEM)
14
13.21%
Fram
1.89%
Baldwin BT7349
15
14.15%
Wix 57620 (NAPA 7620)
10.38%
Wix 57620XE (NAPA 7620XE)
2.83%
Purolator PureOne
1.89%
Purolator
2.83%
Donaldson P558615
0
0%
Mobil 1
0.94%
I have a bypass too!
1.89%
Multiple Choice Poll. Voters: 106. You may not vote on this poll
Old 03-05-2011 | 01:40 PM
cougar's Avatar
1st gens aren't picky. A coffee can full of pea gravel works fine.
Old 03-06-2011 | 12:28 AM
HMX-1's Avatar
Originally Posted by madhat
I just use the OEM. Get them at the dealer most of the time.
Same here ..... my dealer in Boise offers a killer deal on oil changes and I have it for both my trucks.
Kris
Old 03-06-2011 | 08:50 AM
surfram's Avatar
I am currently running the Hastings LF608 which is identical to the Baldwin BT7349. I always ran Napa Gold/Wix 7620 or 7620XE before I decided to try the Hastings. Just by visual analysis, the LF608 appears to have better filtration than the regular 7620.
Old 03-06-2011 | 10:45 AM
DWeiler's Avatar
Amsoil plus a Magnetic "Filtermag"(RA 365,600lbs of pull )on the oil filter plus one on the Amsoil bypass.Tranny has a external filter kit and runs a Baldwin BT 839 with another 365Filtermag,excessive but peace of mind.---fuel system will be similar DW
Old 03-08-2011 | 06:33 PM
Rednax's Avatar
I've ranged around from Donaldson (the best) to my now usual choice of BALDWIN. The same injector shop carries this, the FF7977 and Stanadyne. Every oil change gets these plus new air filter and T-6 (about 2-3X yearly).
Old 03-08-2011 | 06:58 PM
wcbcruzer's Avatar
Donaldson ELF7349 here... Pretty much the best spin-on filter you can buy. Change it every other oil change.. About 10-12k miles.
Old 03-08-2011 | 07:18 PM
R.A.Masala's Avatar
Has anyone tried a System1 filter? I use them on my race car.Gonna look and see if they have one that will fit.
Old 03-08-2011 | 07:22 PM
patdaly's Avatar
Originally Posted by signature600
Stratapore LF16035
Chris
Same here
Old 03-08-2011 | 08:00 PM
Hvytrkmech's Avatar
I use Hastings LF608, same thing as the Baldwin.
Old 03-08-2011 | 08:55 PM
rebal's Avatar
Wix (Napa 1607 ) been using it for 20 years and 700,000 miles
Old 03-09-2011 | 10:25 AM
AH64ID's Avatar
They range from 30 to 75um, not the greatest as far as filtration goes.
Old 03-09-2011 | 11:40 AM
Dr.Dizzle's Avatar
I use the Donaldson ELF 7349 and the Amsoil BMK 21 bypass.
Prior to installing the bypass, I used several of the Fleetguard Venturi Combo lube filters - LF9028 on the company vehicles as well as my own. Prior to doing so, I corresponded with a Fleetguard representative over the phone and via e-mail. I was informed that it was created for Kubota applications and the Chrysler spec. calls for a full flow element and not a combo style filter,however; the LF9028 could be used on the Cummins 5.9.
Old 03-09-2011 | 01:09 PM
Stargeezer's Avatar
What does the bypass do for you?
Old 03-09-2011 | 01:29 PM
AH64ID's Avatar
It filters the oil much finer than a full flow. If you look at the Amsoil/Donaldson filters, which have the best ratings, they filter out 98.7% of all particles 15um and larger. An Amsoil bypass, which gets about 10% of the oil at a time, filters out 98.7% of particles 2um and larger.
So you end up with much cleaner oil, and less engine wear from particulate in the oil.
Old 03-09-2011 | 05:11 PM
Stargeezer's Avatar
Does it replace the factory filter system or operate in addition to it?? How does dodge feel about them in the event of a failure? I'm all for increased filtration and would add this in a heartbeat, but I don't want any issues with my warrenty.
Quick Reply: What oil filter do you use?
