What kind of engine is this?
This might be in the wrong forum.. I though it fit best here.<br><br>My question is, what kind of engine would this truck have and what kind of engine is on its back?<br><br>http://tonopahpictures.0catch.com/relics.html
Re:What kind of engine is this?
what year is that a 47........<br><br>it has the same cab as my dad's 50 2 ton but the front clip is different ???<br><br>I don't know if they're the same or not but his 50 has an overhead valve six just over 200 cubic inches (230 I believe)<br>and it makes about 65hp .......<br><br>
Guest
Posts: n/a
Well, since you're from Tonopah I searched around and I think it's a '37 with a 216 straight 6!! I'll take a guess on the back at some sort of a 2 stage air compressor. Now that you posted those pictures on the net, all them crazy hotrodders will head out in the desert lookin' to buy it !!
Well, since you're from Tonopah...
I saw this truck and wondered what kind of power was under the hood.
Just curious is all.
I'm only a guessing --but -- It looks like you were at a old mine working area? Copper mine probably----being there. The truck looks to be a Air truck used for starting BIG haul trucks and also for general use, where ever they needed a big air compressor for drills an such. The compressor engine could be a Walkashaw - a continintal or ????? they used allmost anything back then . I remember seeing a v 12 packard conversion once , so unless we could see some closeup shots of the engine in question. long story short I don't know.
Think he's right on the 216, the 235 did not come in until later and the 230 much later. Does seem like they had a 194 or a 196, something like that in some of the early models. I know that a bunch of the war 40's trucks had 216.
yeah looks like 216 is right, I did a bit of web searching, <br><br>looks like a 37-39 body style and the engine then was a 216<br><br>the 235 and 261's came out around 42........
Location: In the middle of Weather Dry Creek Farm in Avilla, Arkansas
1 Post
I wonder if the unit in back is a LeRoi(Leroy)? The military had<br>a bunch years ago. They were a V type engine with some of the cylinders converted over as an air compressor. Haven't seen any in years.<br><br>Bruce
I saw aTV program about a flying nuclear reactor that was tested in Tonopah in the 60's. Part of that testing included forcing mass amounts of forced air through the thing. I sure there were air compressors lying around all over the desert after they were finished. The air tank used was something on the order of 2 square miles.
DieselDaze, that thar looks like the 1936 Chebby truck on which I lerned ta drive back in da fortys. Looks like some removed da bed tho and added a few extra LB-FT o torque.
On the back, I agree with duelin. It looks like a two-stage air compressor {I-R maybe} (note the reciever tanks behind the cab), driven by what looks to be a gasoline F-1197 Waukesha (back then called a WAK).<br><br>
