V8 to CTD Swap
Old 11-03-2004 | 03:43 PM
TexasHardcore's Avatar
V8 to CTD Swap
I'm curious to know what it'd take to swap a 12V into a gas powered (V8 or V10) 2500 or 3500 2nd gen Ram?
I'm wondering about Motor Mounts, Radiators, Trans/Bellhousing, Starters, Trans Mounts, wiring, etc.
Anyone performed this swap or know what it takes? I did a search but didn't find specifics...
Thanks
Old 11-03-2004 | 05:43 PM
Lockdown's Avatar
https://www.dieseltruckresource.com/...threadid=49766
That was my idea of building a 1500 diesel but it got shot down... but there is good info on what you need to swap it out. Not much involved with a 12 mechanical... just a few wires and it'll run heh.
Old 11-03-2004 | 05:56 PM
Well I can understand that. A 1500 frame & suspension just won't cradle a heavy Cummins motor unless it's seriously beefed.
I'm just wondering what it'd take to do a straight forward CTD swap into a 3/4 ton gas truck. Shouldn't be hard, just looking for specifics.
Old 11-03-2004 | 11:22 PM
96_12V's Avatar
You will need to change the tank, the fuel lines, the engine controller if applicable, and probably the front suspension if it's a 2500 (would need to check on that one.) The brakes are also uprated, as it's a heavier engine. Really it's eaiser these days to simply find another truck than to swap gas to diesel. Just my $.02
Old 11-04-2004 | 07:02 AM
jughead's Avatar
guess i should stay out of this one. when my 1/2 ton frame cracks i will be the first to let this board know
Old 11-04-2004 | 09:00 AM
Smokee's Avatar
yeah, Jughead. Mine never cracked either. I compared the frames side by side on a first gen and there was no difference except for suspension components. Motor mounts, etc. bolted right up.
I put over 200,000 miles on it.
Old 11-04-2004 | 01:57 PM
diesel_kid's Avatar
What is the weight differences between a 12 V and a Big V-8 such as a 460 or even a 350? Also how hard is it to get ahold of the 3.9B Diesels. I told my friend he should put one of them in his little 86 S10 instead of a big 350. How heavy are the 3.9s? Thanks.
Old 11-04-2004 | 05:00 PM
Lockdown's Avatar
12v = Roughly 1k lbs
350 = 500-650 lbs ( I haven't found a good source yet for this)
3.9 4bt = Roughly 600 lbs (basically a 6bt with 2 cyclinders cut off)
3.9 diesels are easy to get ahold of. All frito Lay trucks had the 3.9 and are willing to sell off their old retired trucks if you contact them, cheap too. 3.9 would be a great engine for a s10. I've read of people getting 500 ft/lbs of torque out of them with no problems... think of hauling up a hill with that.
Old 11-04-2004 | 05:50 PM
diesel_kid's Avatar
What kind of mileage would you get out of a 4bt? I really like the sounds of this, swapping in this engine into an S10 or smaller truck. If you could easily get 300-350 hp out of them that would be great. Thanks lockdown.
bigwheels94
07-11-2008 03:10 PM
Treangen
63
07-07-2008 07:42 PM
Redleg
06-13-2007 12:04 PM
RamSST
06-02-2007 02:07 AM
Just4Smoke
06-08-2006 11:26 AM
Quick Reply: V8 to CTD Swap
