Turbo slang/codenames
Old 08-02-2005, 08:22 AM
2500CTD's Avatar
OK, I'm looking at twins, researching and reading and finding a couple good canidates, but I have no idea where to find them. Not all these but for instance: B2, Big brother, S300, there are others I cant remeber now. I guess the B2 related to the infamous B1. but the S300 or S400???? I see a couple I might use in my planning but having trouble finding them on line. Is there a made up a list of these? anyone???? I understand turbos, just not the slang or code names for 'em.
Old 08-02-2005, 09:31 AM
durasmack's Avatar
Someone needs to compile a listing of what all of them are from different companies..... What Garrett turbos are like the Holset turbos, etc..... I dont know much about them, but would like to know if anyone has the information.
Old 08-02-2005, 12:29 PM
joefarmer's Avatar
From what I remember:
B2 - based on the schwitzer S400, commonly in a 74mm inducer wheel.
Big Brother - based on the same schwitzer, just larger wheels/housings?
B1 - roughly based on the schwitzer s300, many different ex-housings available.
I haven't found a cross reference for different turbos either... there was one floating around that had a listing of cfm or lbs/min, but I was under the impression that it was incorrect. Holset and Garrett guard their compressor maps with care. I've not seen a schwitzer map either. Turbonetics has some excellent reading and maps on their site:
http://www.turboneticsinc.com/compmaps.htm
brnadon.
Old 08-03-2005, 11:30 AM
2500CTD's Avatar
brnadon.
I saw that list, it also listed street and race HP?? So who makes Schwitzer?? A source for them?? Thanks Oh you ever get tired of people telling you you spelt your name wrong!
Old 08-03-2005, 01:40 PM
HOHN's Avatar
Schwitzer is Borg-Warner turbo systems. The company has undergone lots of name changes, which only confused things more.
KKK became Schwitezer, which became Borg-Warner Turbo Systems.
Old 08-28-2006, 03:37 PM
PanteraGSTK's Avatar
I found this while trying to find an answer to the same question. So. BD's super b is an s300 right? a B2 is an s400. What is a B1? what about companies like Industrial injection and High Tech Turbo? They modify name brand turbo's right? Which ones?
The reason I'm asking is I've found s300's from anywhere from $950 to $1500. and they look the same with the exception of extended tips and such. Could somebody clarify.
Old 08-29-2006, 03:04 PM
joefarmer's Avatar
B1 == modified s300 or variant. II and HTT typically start with Schwitzers. I don't know too much beyond that.
brnadon.
Old 08-29-2006, 09:43 PM
BigBlue's Avatar
All I know is that an HX35/HT3B is a tried, true, and great setup. The BD twins which use a superB S300 on top and a special S300 on bottom is a very, very, very nice setup (just ask rjohnson). A ksb-1/B2 combo is a great 600+ setup that's pretty streetable as well.
Old 08-29-2006, 09:48 PM
Begle1's Avatar
So, should we compile a list of turbo names, modifications and boost/ CFM limits?
I'd be up to it. (Well, I'd be up to nominating BigBlue to be up to it, then taking all of the credit after he finishes...)
Old 08-29-2006, 09:53 PM
BigBlue's Avatar
And you wonder why you have 4 red bars.
Old 08-29-2006, 10:13 PM
Begle1's Avatar
5 red bars...
So, just playing aroud with a possible format:
S-300: A popular Schwitzer turbo used as a single or top on a twins set-up; also known as a B-1. Modified versions include (a vast array of stuff I don't know).
S-400: A popular Schwitzer bottom turbo; also known as a B-2. Modified versions include the Big Brother.
H1C: The Holset turbo which debuted with the Cummins; available in 12, 14, 16, 18.5 and 21 cm exhaust housings, these turbos provide flexible and consistent air for up to 250 horsepower.
WH1C: A wastegated H1C, replacing the H1C in 1992~ish (maybe?) and available in 12 and 14 cm exhaust housings.
HX-35: The stock Holset turbo from 1994 to (insert proper year) on manual trucks; can be modified to various "levels" of performance through application of money.
HY-35: The stock Holset turbo from (blank to blank) automatic-equipped trucks; it has a 9 cm wastegate housing which makes it suck.
HX-40: These were on something, right?
HT3B: A very large and cheap Holset turbo prolifically used as a very efficient bottom twin turbo.
HX-55: A Holset turbo which has been used as an alternative to the more popular HT3B as a bottom twin.
Something like that good, or do we need something more like an Excel graph?
Old 08-29-2006, 10:22 PM
BigBlue's Avatar
Pretty good I think.
Old 08-29-2006, 10:41 PM
Begle1's Avatar
Feel free to copy it and make it better.
Old 08-30-2006, 01:35 PM
v8440's Avatar
Might want to add stuff like the htb2 turbos from htt. I think they're fairly new on the scene, but are picking up quickly in popularity.
Old 08-30-2006, 02:57 PM
Lil Dog's Avatar
You would also have to have a separate catagory for Hybrid 35/40's such as the Dodgezilla etc...
The HX-40 comes on the C series Cummins IIRC... Hense the ease of availability.
H1C was the first gen turbo 89-93 in minor variations.
WH1C was on the 94 2nd gens debut. Replaced later with the HX-35.
Quick Reply: Turbo slang/codenames
