truck pull
Old 02-08-2005 | 03:56 PM
diesel_burner's Avatar
truck pull
just a quick question, has anybody ever done a tracor pulled with manual tranny, and if so how hard is it to shift gears with out losing momentum. also what kind of clutch would you run. i was wondering because it seems like it would be a lot easier in a auto.
Old 02-08-2005 | 04:55 PM
WhiteSport600's Avatar
You can't shift, you need to start off in one gear and leave it there. Too low a gear and you won't have any momentum, too high and you'll never take off... It just depends on how much power you have and what clutch...
Old 02-08-2005 | 05:55 PM
graphitecumnz's Avatar
no shifting... get a good clutch, dual disc or a big SBC... pick a high gear... 3rd or 4th.... rev the engine to a high RPM and let that sucker eat dirt...
Old 02-08-2005 | 08:32 PM
yeah i've seen some of those videos and you see those guys slam the hammer down. would you guys say that you could get a better set up with a manual tranny or and auto? i wouldn't mind trying this out some day after i get my truck set up. another question are the pulls mostly in the summer time? thanks for all the feed back.
Old 02-08-2005 | 09:25 PM
http://scottsram.homestead.com/ScottsRam.html
here's a good site to learn about setting up your truck for pulling sleds... hope Scott doesn't mind.
Old 02-08-2005 | 09:33 PM
sweet, thanks.
Old 02-09-2005 | 12:05 AM
Kman9090's Avatar
I have a 2001 CTD with a 5spd, and i was also thinking about pulling my truck over this summer, but was wainting to get a little bit of information on gear selection. I thought I would start off in 2nd in 4LO, but wasn't for sure. Dont get me wrong, Im not looking to pull 300 feet, im all stock, just waiting to have a little bit of fun.
Old 02-09-2005 | 06:21 AM
don't pull in 4LO and 2nd gear... you need to pull in 4HI and at least 3rd gear, especially stock.
Old 02-09-2005 | 09:04 AM
halerazor's Avatar
3rd gear in high range NO WAY!! i can barely get my truck to take off in 3rd without a load. theres no way your gonna start out in 3rd with a sled behind you. most everybody uses 2ND HI or 3RD LO. you can pull 4TH in LO but if you don't have the power byebye clutch
Old 02-09-2005 | 09:19 AM
gunracer1's Avatar
stock clutchs, 2 gear low range is about all they can take, you might get away with a 3rd gear pull with a 6 spped. and forget about reving it up and dumping the clutch, the stock clutch will just go up in smoke. the high rpm starts is only for the pulling clutchs, i don't know of one single that can take it. i have a con 13.25 fe and the highest i can come off the line is 2000 rpm anymore than that and it will slip in 3rd.
Old 02-09-2005 | 09:52 AM
Same here on the FE
Old 02-09-2005 | 12:13 PM
sled pulling is not for stock clutches....
my brother pulls and has no problem using 3rd gear launches...
Old 02-09-2005 | 01:02 PM
Kman9090's Avatar
Well im proably going to go ahead and try it out anyway, if I burn the clutch up thats really no big deal, just a good reason to upgrade. But halerazor is right, my truck will not go anywhere if I start off in 3rd, so im guessing my best choice would be 2nd. Thanks for the information
Old 02-09-2005 | 09:51 PM
DeereDiesel's Avatar
First time I hooked on the stock clutch 3rd lo, tried to wind it up and dump it, time for a new one . Man ive come a long way since then, but the wallets a little lighter
carty
92smokin blacky
06-11-2009 10:17 AM
dodgemaniac
Competition / Pulls / OffRoad
08-05-2007 12:42 PM
PourinDiesel
07-21-2007 12:42 PM
Bobcat698
18
08-03-2006 09:23 PM
zookeeper
07-19-2005 09:40 PM
Quick Reply: truck pull
