Stright Pipe
Stright Pipe
I have a 1998 Dodge CTD 24valve. When i got it the only thing that was done to it was the muffler was taken off. I love the way it sounds. But is that killing my horse power or did it give me more because of free flow. Also what other things can i do to get more ft lbs besides a chip and exhaust. Thanks Mike
Running a straight pipe really doesn't add or subtract any HP. However, it does help with lowering EGT's (exhaust gas temp). Getting more air to the motor helps also. Do a search on BHAF or Scotty air systems. The only way to add any real HP or torque is by adding more fuel. This can be done fairly cheap with fueling boxes (EZ, VA, that can run around $300-400 used) or injector swaps which you can find good deals on used ones from folks who are moving up to bigger ones. The RV275's or DD2's are nice upgrades for not much $$$.
The 12 valve was the last mechanical diesel engine. The 24 valve is electronic. The difference with bombing is that the 12 valve is cheaper but takes more time, the 24 valve is more plug and play. I think that its just a matter of personal preferrence. They both have their demons (pumps for the 24 V and the KDP in the 12 V, either one can have a #53 block, or so I've heard) and both are fine engines that will last a long time if properly cared for.
dodge em
17
06-15-2009 05:01 AM
BEARHUNTER
19
06-24-2008 12:31 AM
mikegronholz
22
12-06-2006 08:38 PM
evan4434
06-08-2005 07:37 PM
