Rear Axle Problem???
I have a 2001 Ford Excursion, and am not sure if I have a rear axle problem or not. Was checking the rear brakes & with both rear wheels off of the ground & tranny in neuetal, I could barely spin the axles. Disconnected the driveshaft and the drag was a little less, but not much. Also, when I would spin one wheel, the other would spin in the same direction - as if the differenial was locked. Is all of this normal.
I checked the fluid level & it was just a little low, but I could get some on my pinky. It looked/smelled good, but I just changed it about 30,000 miles ago.
Does all of this seem normal?
nvr-enuf
01-30-2014 06:56 PM
ian515
07-24-2009 03:22 PM
MX429
08-20-2006 06:41 PM
