Propane injection to the extreme?
Old 05-22-2003, 07:14 PM
Check this out. Uses Diesel to light the CNG/LNG, could probably be set up for propane. Anybody with a propane system know how much propane you run compared to how much CNG/LNG this thing can stand?
Edit: I don't know why I can't get the G-D link to work right, >but if you look under engine info/specs, then current engines, then dual-fuel, you'll see what I mean. I'm computer literate, but just barely, I guess. :P
Old 05-22-2003, 09:31 PM
SjLingenfelter's Avatar
Re:Propane injection to the extreme?
What it saying is that it uses Diesel/CNG-LNG to take off then when coasting on the highway it uses CNG-LNG. Bascily like add a 200 shot of LP to your truck and taking some of the Diesel away. Its like 50/50. The thing is that CNG-LNG is heck of alot cleaner and doesnt blow smoke. I know the PSD's can handle aleast a 200 shot of LP. I wonder if our trucks can run CNG-LNG?
SD03
Old 05-23-2003, 12:46 AM
westcoaster's Avatar
http://www.westport.com/products/index.php
here is cummins product line...
edit...
follow the links... http://www.cumminswestport.com/
Old 05-23-2003, 01:03 AM
Although I think the Cummins engines have spark plugs...
Old 05-23-2003, 07:06 AM
Stamey's Avatar
[quote author=westcoaster link=board=8;threadid=15041;start=0#141230 date=1053669804]
[/quote]
You mean glow plugs?
Old 05-23-2003, 08:51 AM
rharveysr's Avatar
And they are owned by Ford..... : : :<br><br><br>Rick
Old 05-23-2003, 09:05 AM
Top's Younger Twin
Scotty's Avatar
[quote author=rharveysr link=board=8;threadid=15041;start=0#141303 date=1053697881]<br>And they are owned by Ford..... : : :<br><br><br>Rick<br>[/quote]<br><br>LUMPY + SHEEP... :
Old 05-23-2003, 09:38 AM
Westport Innovations Inc., through its joint venture Cummins Westport Inc. (CWI), has a wide range of low-emissions, high performance natural gas powered engines for many applications. We have contributed our Westport-Cycle™ technology and other proprietary natural gas technologies, and Cummins has contributed its current on-highway vehicle medium-duty spark-ignited natural gas engine businesses and proprietary engine-related technologies for on-highway vehicles, industrial and power generation applications. Cummins manufactures the engines for CWI and those engines are exclusively distributed and serviced by the Cummins global distribution system.<br><br>More detailed information on the entire CWI product line is available at the Cummins Westport website at: http://www.cumminswestport.com.<br><br><br><br>no... I mean SPARK plugs... at a 10:1 compression ratio and a full natural gas or propane engine how else do you make it ignite??
Old 05-23-2003, 09:44 AM
[/quote]
No Diesel/Propane/LNG injected motors have spark plugs its either heating grid (CTD) or Glowplugs (Ford&amp;Chevy). Its all done by Compressed ignition. Even if it has a lower compression ratio than normal.
Old 05-23-2003, 09:51 AM
I was probably miss reading this paragraph and lead me to make the statement about the spark plugs...<br><br>and Cummins has contributed its current on-highway vehicle medium-duty spark-ignited natural gas engine businesses and pro
Old 05-23-2003, 09:54 AM
BigBlue's Avatar
[quote author=SuperiorDiesel03 link=board=8;threadid=15041;start=0#141333 date=1053701060]<br>[quote author=westcoaster link=board=8;threadid=15041;start=0#141230 date=1053669804]<br>Although I think the Cummins engines have spark plugs...<br>[/quote]<br>No Diesel/Propane/LNG injected motors have spark plugs its either heating grid (CTD) or Glowplugs (Ford&amp;Chevy). Its all done by Compressed ignition. Even if it has a lower compression ratio than normal.<br>[/quote]<br><br>I think he was joking.
Old 05-23-2003, 01:45 PM
tmiller24's Avatar
Anybody have a clue how little compression it takes to keep our engines running? Can 10.5:1 still ignite diesel?<br> Tony
Old 05-23-2003, 03:32 PM
bneaves's Avatar
It will all depend on the intake air temp and the fuel atomization. For diesel fuel to ignite it takes a minimuim of 450 degrees Farenheit. If you didn't run an intercooler and coudl really get a super fine spray from the injectors, then it &quot;MIGHT&quot; be enough, but only after the engine got warm.
Old 05-23-2003, 03:52 PM
If you read these articles by Bruce Mallinson, on big Cummins motors he drops the compression down to 14:1, cranks up the boost and fuel and retards the timing. He's going for million-mile longevity in class 8 trucks while making 2500 ft/lbs of torque, so his goals are a bit different than ours.
Old 05-23-2003, 04:01 PM
6.5:1 isn't enough.
Quick Reply: Propane injection to the extreme?
