One Dead Yanmar
Old 10-02-2006 | 09:36 PM
DieselDaze's Avatar
Originally Posted by 96_12V
... what's the possibility of the dealer you purchased it from helping you out a bit? Might be worth asking, at least.
They just nod their heads and say "shucks, thats too bad... We just got this new one in... "
Actaully, the dealer has been very good to me. They have helped since I bought the thing by providing me little stuff at cost.
But they keep reminding me that I bought it "as is".
I spoke to the shop foremen tonight and he mentioned that these engines can go 30 over.
He also stated that getting the crank turned on this engine is very costly, but he couldnt remember any prices associated with "costly".
With any luck, I'll get some time this weekend to pull the pan and check out the bottom end. I think I should get a pretty good idea what Im in for once I drop the pan.
Anyone want a used JD?
"Runs rough, needs work"
Only kidding.
Rich.
Old 10-02-2006 | 09:41 PM
v8440's Avatar
Thirty over, that ought to take care of the cylinders unless you really scored them good. So far as turning the crank, I can't think of a reason why one crank ought to be much more expensive than another to turn. I suppose there could be something about the crankshaft that makes it hard to set up in the machine, or something like that. I'm willing to bet that if you take it apart and take the pieces to a good general automotive machine shop, you'll be able to beat the prices you've gotten by a wide margin.
Old 10-02-2006 | 09:48 PM
96_12V's Avatar
Diesel Daze,
I'll keep looking, but found this one that may help....
http://cgi.ebay.com/New-Crankshaft-f...QQcmdZViewItem
He also has a whole 950...
http://cgi.ebay.com/ws/eBayISAPI.dll..._promot_widget
Old 10-03-2006 | 06:47 AM
DieselDaze's Avatar
Thanks guys, I appreciate all the input.
96_12V,
I may give that seller a call.
Rich.
Old 10-03-2006 | 09:13 PM
CG98x's Avatar
We've got a yanmar tractor with the 3 cyl 33 hp motor in it. It is a very stout built engine. Someone had run it out of oil and we had to put a used short block in it because there was a rod sticking out the side of the block but it has run good for us. i think our used short block was about $2000. Good luck
Old 10-03-2006 | 09:15 PM
DieselDaze's Avatar
By chance, you remember where you found that used short block?
Rich
G1625S
07-27-2012 06:25 AM
dodge lightning
0
12-20-2006 11:57 PM
DieselDaze
09-15-2006 03:10 PM
Dodgecaveman
06-22-2005 12:11 PM
DieselDaze
12-22-2004 04:54 PM
Quick Reply: One Dead Yanmar
