Ok to run 245's in rear and 265's in front?
I'm going to haul an in-bed camper and I'd like to replace the rear tires since they're not in great shape. The front tires are still ok. All the tires on the truck are currently 265/75/16 load range D. I've got 4 new 245/75/16 tires load range E tires at my house. I'd like to fix the death wobble and get the front-end aligned before I put the new tires in the front, but I'm not sure if I'll be able to get to it in time. Do you guys see any problem in running 245's in the back and 265's in the front? I think they're about the same diameter.
Muted User
if you use the 4x4 you will probably bust the t-case, if you absolutely have to have the tires put on, get two 245's and have them put on the front. used or new dosent matter.
Thanks for the input. I won't be using 4wd. So I guess it should be ok then huh? Either way, I'm going to try to get the front end fixed asap. I'd just hate to put on a new pair of tires in the front and then chew them up because of poor alignment and death wobble.
Location: Smith Valley, NV (sometimes Redwood City, CA)
John
Common
05-03-2008 10:15 PM
nibroc
22
02-09-2007 09:59 AM
StrokeThis2500
02-13-2006 03:30 AM
