NW PA, NE OH, Hot Stock Diesel Rules
FOR PRE-PULL INFORMATION, PLEASE CALL: <br>Joe Nuhfer (724) 932-5202 <br>Steve Polkabla (814) 786-9716 <br><br>2003 Northwest(PA) Hot Stock Diesel 4x4 Truck Rules <br><br><br>1. Licensing - All vehicles must have a current license plate in place. PA licensed trucks must have current inspection sticker. Proof must be shown of ownership, insurance and inspection. <br><br>2. Fuel - DIESEL ONLY. No oxygen accelerators. Water injection is allowed. No Propane, Nitrous, or alcohol. <br><br>3. WEIGHT - 8000 lb. class. Weight brackets or hanging weights allowed on front end and must be properly secured. Furthermost point of weights and/or bracket will be 60 inches from center of front axle. Weights may be in cargo area inside the bed and must be secure. Snow Plow brackets allowed but no plows. <br><br>4. HITCH - Adjustable hitch, stationary in all directions, hook point being the furthermost point rear of the vehicle. Puller must supply his or her own clevis and pin and be ready to pull. 3inch I.D. minimum diameter on all hitches. Hitch height will be 26 inch maximum. <br><br>5. TIRES - Street legal with D.O.T. number. Maximum tire tread width of 10 inches. No modifications to tires. Dual wheels allowed. No split rims, studded tires, or chains. Maximum tire size will be 35x1250 as stamped on tire,. <br><br>6. ENGINE - OEM Stock Diesel pick up truck engine. Two (2) turbo charger permitted and must be shielded with 1/4 inch steel or 3/8 inch aluminum. Steel inner fenders, frame rails and steel hood may be considered adequate shielding. <br><br>7. TRUCK BED - Vehicle must have a bed in place. Wooden flatbeds are permitted, but must have sides and fenders to cover rear wheels. <br><br>8. SUSPENSION - No solid suspension. Stock suspension must be in place. Rear blocks must have a minimum of 1 inch clearance, in all directions. Blocks must be securely fastened. One (1) suspension block per side. Spring clamping is permitted. Four (4) clamps per axle. <br><br>9. EXHAUST - Must be in place. Headers permitted. All exhaust must exit the body. <br><br>10. BRAKES - Must be in place and in working order. <br><br>11. GLASS - All windows must be in place. Windshield and driver's side window glass may not be smoked. <br><br>12. SAFETY - Fire extinguisher in cab is required. Drive shaft loops and universal joint shielding required for all modified turbo charged trucks. Drive shaft loops will consist of 3 loops of 5/16 inch steel or 3/8 aluminum with 1/8 inch steel insert. Seat belts are required. Helmets are required. <br><br>13. Blow proof bell housings or SFI approved transmission blankets required. <br><br>14. Air shut off on two (2) charger trucks. <br><br>15. Any driver arguing with a track official is subject to immediate disqualification,. All decisions will be final at each pull. Any protests will be settled at the next club meeting. <br><br>16. If more than twenty-five (25) trucks are registered in a class, the Competition Director has the right to waive the 75' rule. Pullers will be notified before the class starts <br>____________________________________________ _ <br><br>This will be run for points. If you want into the points race, registration must be before May 1st.I will post the schedule soon. Should be at least six pulls. If you have any questions, e-mail me at Dieselrules@sledpuller.com<br>
Re:NW PA, NE OH, Hot Stock Diesel Rules
Waiting to get the contracts finalized, but it is looking like:<br><br>Jefferson Township fair, July 23/24<br>August 10 Ashtabula, Ohio<br>Stoneboro Fair Sept1 Labor day night<br>Waterford Fair Sept 2<br><br><br>Sheakleyville Homecoming, ?<br>We willl probably run exhibition at Meadville Fair<br>
Strjock81
16
12-12-2007 09:53 AM
duallydave
08-07-2005 09:38 PM
