Need some help w/ tire problems
I need some help figuring out what to do about a tire situation.
I bought the truck w/ 285/75/16s on the front, and 285/85/16s on the back.
Last year I did not experinece any trouble w/ the tire difference in 4x4 because I didn't run 4x4 on dry road, just mostly in snow, or deep mud.
But I would like to get the same size all around.
I had to replace the front set of tires and I replaced them w/ 285/75/16s and now it is time to replace the back set.
What should I put on the back? Are the 285/75s too wide? If so can I purchase a wheel spacer to acomodate width?
I need some help. Basically I don't want to replace all 6 tires, when my front 2 are brand new.
Yea I wanna keep the size.. It is just that I got two brand new 285/75s up front and I would like to get the same series on the rear.
Do you think two inch spacers would accommodate and not cause the tires to rub?
go to www.performancewheel/spacers- they make spacers for duallys and can tell you exactly what will be best for your app.
Both those tires have the exact same width, but the 285/85's are 2" taller, there 35" tires, while the 285/75's are like 32.8" tall. I want to run a 33" or taller tire on my stock 16" wheels but wasn't sure it was ok, but it sounds like I could run those 285/85/16's with just a 1" or 2" spacer and be good to go.
So if u can fit the 285/85's, the 285/75's will be the exact same width, just shorter by 2 inches, but if they rub alittle, u should prolly get a small spacer just to add some space between the duals.
Como4076
08-12-2008 07:49 PM
rip 112
34
03-07-2008 04:05 PM
JKM
11-22-2005 01:38 AM
j28s
11-04-2002 03:14 PM
