My little tractor
Old 09-05-2007 | 10:30 PM
sixb's Avatar
My little tractor
That bail weighs 875 lbs and the tractor 1250 without the bucket.
Old 09-05-2007 | 10:55 PM
crobtex's Avatar
Back tires look a little low.
Old 09-06-2007 | 06:19 AM
JD730's Avatar
I'm impressed. I wouldn't think the hydraulic system would even pick up that kind of weight. What is that bale, 3x3x7 or 8?
Old 09-06-2007 | 06:33 AM
G1625S's Avatar
I run one of those at work. Trusty little machine. Loader won't lift much to speak of, but the 3pt has some stones
Old 09-06-2007 | 07:51 AM
sixb's Avatar
JD730 Probably 8' but I would have to measure. I only use it for the horses so the bucket is a real back saver when it comes time to clean the paddock. I have a 2 yard dumpster/trailer that gets dumped every other week. With a homemade trailer hitch on the 3pt I don't even have to get off the tractor.
Old 09-06-2007 | 07:55 AM
TreeFarm's Avatar
Okay. Now let's see ya set that bale up in the bed of a truck.
Old 09-06-2007 | 08:13 AM
dieselfuelonly's Avatar
DTR question asker
Wow that is a lot of weight, I'm surprised it would pick that up!
Bet it was fun when you had to get started from a standstill huh.
I put a few good sized logs on the carryall on the back of my little Yanmar and unless I started out in low range the front end would get REAL light!
Old 09-06-2007 | 09:58 AM
hamilton71801's Avatar
Is that a 7510? I had one but it wouldn't run my finish mower so they took it back and upgraded me to a 7610. It's amazing what these little "toys" can do.
Old 09-06-2007 | 10:19 AM
sixb's Avatar
I load 12 bails on my 20' gooseneck and use my wifes durango to drag them off the trailer. The front end does get light, but not bad. It's a bx1800 and definetly no toy.It will dump a load of dirt in the bed of a truck.
Old 09-06-2007 | 11:34 AM
TreeFarm's Avatar
But will it turn this tight while doing it?
Old 09-06-2007 | 12:01 PM
Diesel_Storm's Avatar
kinda like my aunt and uncle's Steiner. they have 2 of those Steiner tractors that bend in the middle.
Old 09-06-2007 | 12:08 PM
DTR question asker
If I step on one of the foot brakes I might be able to .
There sure is a cool little machine... what exactly is it? M4WD?
Old 09-06-2007 | 12:15 PM
TreeFarm's Avatar
No Steiner dealers around here, thus, no Steiners.
That one is a Power Trac. Four wheel hydraulic drive. Hydraulic PTO, too. No dealers for them anywhere. Factory direct only, and you get to wrench it yourself -- frequently, I might add.
Old 09-06-2007 | 12:30 PM
DTR question asker
Ok, I had seen something similar to one of those over on the TractorByNet forum.
What kind of motor does it have?
Old 09-06-2007 | 01:05 PM
TreeFarm's Avatar
Yes, TBN is the only active Power Trac board I know of.
Mine has a 25 HP Kohler. I believe the current production gassers have air cooled Robins, while all the diesels are air-oil cooled Deutzes.
Power Trac has a website, http://power-trac.com.
Quick Reply: My little tractor
